I had my 1950 Champ in storage about 7 years. A local shop got it running and put a new battery in it. The battery was grounded to negative. The car ran and I drove it about 2 months - maybe 50 miles, I noticed that the amp gauge did not show the system charging but I assumed it was old and not working. On acceleration, it showed a discharge, I went on vacation and the battery was dead after about 2 weeks away.
When I recharged the battery and tried to start it, the starter (which had been weak) wouldn't turn the engine. I took it off and after it was rebuilt, I hooked up the wiring like it was and it won't start. I need help to get it wired right and the car running. I have a shop manual.
I assume the positive lead from the battery should have been hooked to the ground strap to the engine block? The shop had it negative grounded. On the starter relay (solenoid), the negative post should attach to the top and the wiring harness to the bottom? Or is nothing on top? the positive wire from the coil should attach to the distributor? Did it short the coil?
Is the voltage regulator now reverse polarized? If so, how do I correctly polarize it? Are their other things I should try? I just realized the battery was reversed by the shop when I checked the wiring diagram. I was happy the car was driveable after a long absence.
All help would be greatly appreciated. I know I'm not the sharpest knife in the drawer. Maybe that's what makes me love the Champ.
