I have a pair of n.o.s. shocks # 1545052 "they're marked 59 - 62" Lark + Hawk, will these fit 63 - 66 Larks/Lark types or were some changes made to the Chassis ?
Rear shock applications ?
Rear shocks were changed in 1963 to lower stud mount. 1962 and earlier were loop mount on bottom. (Or maybe "bushing and sleeve" would be a better description according to my Monroe catalog. A loop mount is technically a rubber bushing that doesn't use an inner sleeve.). No matter what, '63 and later are very different.
So the lower end of the later rear shocks are the same as the lower end of front shocks from the same era. "thanks for the info"
Originally posted by Studebakercenteroforegon View PostRear shocks were changed in 1963 to lower stud mount. 1962 and earlier were loop mount on bottom. (Or maybe "bushing and sleeve" would be a better description according to my Monroe catalog. A loop mount is technically a rubber bushing that doesn't use an inner sleeve.). No matter what, '63 and later are very different.Joseph R. Zeiger
Originally posted by 63t-cab View PostSo the lower end of the later rear shocks are the same as the lower end of front shocks from the same era. "thanks for the info"
