62 Studebaker Lark master cylinder for use as fluid reservoir
IF you insist on a single M/C, please be sure to replace all the steel lines, wheel cylinders, and brake hoses! ANY of these fail, and you will have NO brakes! Also, be sure that your emergency brake is adjusted and in proper working order!
Might be a good idea to get both E-brake cables new too. Yes, single M/C's worked for decades! But, we do not drive these cars enough to keep everything from going bad from sitting. I was adjusting an e-brake on a Packard Hawk last year, pulled on the cable, and it broke! Got 2 new cables, and when it left, the e-brake worked great.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
I got that you were not going to use that as designed right away on a "K" Model, as others did not.
But I NEVER would have dreamed of that use, now that's thinking out of BOX!
Just grind the "Nose" off of it, and you won't have to cut such a big hole in the Firewall.StudeRich
Originally posted by 52 Ragtop View PostIF you insist on a single M/C, please be sure to replace all the steel lines, wheel cylinders, and brake hoses! ANY of these fail, and you will have NO brakes! Also, be sure that your emergency brake is adjusted and in proper working order!
Jim
Originally posted by altair View PostHere here to every thing you say, I would like to add that even with a dual system the fronts and rears are both fed from the same reservoir, if you loose your fluid both front and rear will still fail. Your directions should apply to all systems
The only other issue with them is, can you actually STOP from Speed with only the front or Rears working without spinning and getting out of control?
Safely, I don't think so.StudeRich
I recently discovered a bad rear wheel cylinder on one of my dual master cylinder relics. I had not checked the fluid level in a while, so I made the discovery when I suddenly had no rear brakes. I still had use of the front brakes. I stopped, found the reservoir for the rear brakes empty, the reservoir for the front brakes still full, then carefully drove home with functioning front brakes. The system worked as advertised.
I converted my 1957 Buick and my 1949 2R5 to dual master cylinders. I have one remaining single MC relic that will also be converted when I can get to it.
I like the original poster's remote fill idea. I will send a PM. Thanks.
