Can a Studebaker pickup with the 3-speed overdrive be flat towed. does the pick up have negative camber like the cars ?
flat towing
When flat towing a pick up, on corners, the front wheels don't like to return straight. That said, I flat towed a 3R11 from Arizona to Indiana. Tied the steering wheel so it did not have much movement. I unhooked the drive shaft and tied it up. When arriving in South Bend, the drive shaft was missing.
If front end geometry causes problems flat towing, why not put it on a tow dolly?
We just towed the 66 Daytona nearly 5000 miles around the country behind the motorhome on a Kar Kaddy, steerable dolly with zero problems. I even got pretty quick with the drive shaft connecting and disconnecting due to it being an automatic.. I placed the drive shaft next to the muffler and used 2 long radiator clamps to secure it. If one's good, two's better. The u-joint caps were taped, put in a heavy plastic bag, and taped to the drive shaft again. Didn't want to pull the drive shaft because the trans fluid would pour out.
Used dollies can be bought cheap on Craigslist, usually. Get one that steers if possible, or at least one that swivels.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
Originally posted by elkriverblue View PostCan a Studebaker pickup with the 3-speed overdrive be flat towed. does the pick up have negative camber like the cars ?
I probably have covered 8 to 10,000 miles with Studebaker Cars on the Towbar behind another Studebaker over the Siskiyou Mountains in Calif. and Oregon.
I learned to avoid sharp turns and driveway aprons, and Gravel at an angle, I also had to crawl, not go slow, to avoid the Left to Right, lock to lock wobble syndrome on turns.
I now prefer a Car Trailer.StudeRich
I flat tow a Champ from time to time. No, it doesn't like sharp turns, driveway aprons (take it at a long oblique if you can) or speed bumps. Other than that, on a straight line, they're fine. I find the trucks easier to tow than the cars. Still would prefer a dolly, if I could find one at a good price. But Dollies have their drawbacks as well. All the same, towing these old vehicles is much easier with a dolly than an a-frame (which has to be constantly checked for tension and adjustment). And yeah, I would remove the drive shaft where I could if either flat-towing or Dolly-towing any distance or with an automatic tranny in the towed vehicle.Home of the famous Mr. Ed!
Ron Smith
Watch Craigslist for reasonably priced dollies. Here in Phoenix they are from $300 to $1000, according to your ability to perform some TLC and rewire one that has had a rougher life or pay more and get one that someone has quit using and just wants it out of their way. I bought my Kar-Kaddy, steerable with surge brakes for less then $1000. Replaced a clearance light and repacked the bearings...good to go.
Originally posted by studeclunker View PostI flat tow a Champ from time to time. No, it doesn't like sharp turns, driveway aprons (take it at a long oblique if you can) or speed bumps. Other than that, on a straight line, they're fine. I find the trucks easier to tow than the cars. Still would prefer a dolly, if I could find one at a good price. But Dollies have their drawbacks as well. All the same, towing these old vehicles is much easier with a dolly than an a-frame (which has to be constantly checked for tension and adjustment). And yeah, I would remove the drive shaft where I could if either flat-towing or Dolly-towing any distance or with an automatic tranny in the towed vehicle.sigpic1966 Daytona (The First One)
1950 Champion 4Dr
1957 Thunderbird
Here in the Peoples' Socialist Republic of California, Car Dollies start at around a grand and go rapidly up from there. However, one is also obligated now to use a device that operates the brakes in the dollied vehicle. I don't know how long it will be before this requirement is mandatory, they are working in that direction though. However, at this time only lights and etc are required (to my knowledge). So, right now, Dollies are a bit expensive for me. A need indeed, however so are parts for Bess, Ed, and Wilber who come first.Home of the famous Mr. Ed!
Ron Smith
My Totota T cab is now on the road. I flat towed it to the alignment shop less then a mile away. Every turn was a fight. My alignment was dead on factory spec. and I just had a yardstick to work with. The cars tow much better if every thing is in spec.If you car is ugly then it better be fast.....
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
Most standad transmissions will not oil properly if only the 'output' end is turning as when towing and the box is in neutral. Remove the drive shaft if you are going very far and like the transmission. If the car has a closed drive shaft, such as a early Ford, pull the shift tower and add a lot more gear oil. The steering wheel can be tied with a piece of bicycle inner tube, or some such compliant material, so that there's no way that the front wheels can go into a 'high speed wobble'.
Are Studebakers with Planar suspension extra hard to flat tow? From my experience from towing a '47 Champion from Onawa to Soldier and a '41 Commander Land Cruiser from Armstrong to Soldier, it seems like they like to wobble and oscillate a scary little too much before they straighten out.1963 Champ "Stu Bludebaker"- sometimes driver
1957 Silver Hawk "Josie"- picking up the pieces after an unreliable body man let it rot for 11 years from an almost driver to a basket case
1951 Land Cruiser "Bunnie Ketcher" only 47M miles!
1951 Commander Starlight "Dale"- basket case
1947 Champion "Sally"- basket case
1941 Commander Land Cruiser "Ursula"- basket case
