I need inst. light switch for my 63 GT Hawk #1558718 anyone have one I could purchase or know where I could obtain one ? 64 I believe is the same(white plastic) I will also take a 62(black plastic) if necessary. Thanks in advance
Instrument light switch needed for '63 Hawk
No offence intended toward you, but I usually get a good laugh at people wanting to fix their Instrument Lt. Switch or Instr. dimmer on Lark Types.
Studebaker instrument lighting is SO dim due to the indirect lighting "Windows" especially the type used on all Hawks with eggshell Blue windows to reduce glare (except '64 with Clear for Red Bulbs) WHY would you EVER think about dimming them?
If you did not want to spend the money or could not find a replacement there are options:
Take the jumper wire off of the Instr. Light Switch and the Headlight switch, connect the output from the Instr. Lts. Sw. to the Instr. Lts. directly to the Term on the Headlight switch that had the jumper to the Instr. Lt. Sw. PRESTO! Always on with Parking or Head lights, always Bright Instruments!
Or for '63-'64's buy the Black Knob Instr. Lt. Switch and paint the Knob, some smaller vendors & swappers will have some, New or Used.
Buy a NOS 1554978 '62 Hawk Defroster Switch, if for a '63-'64 Paint the Knob.
Buy a New Repro Headlight Switch (Black or White) to use for Instru. Lts. you will have Bright on both High and Low.
You will never have a need for any stink'in Instr. Lt. Dimming.Last edited by StudeRich; 11-09-2015, 01:06 PM.StudeRich
Originally posted by kmul221 View PostI need inst. light switch for my 63 GT Hawk #1558718 anyone have one I could purchase or know where I could obtain one ? 64 I believe is the same(white plastic) I will also take a 62(black plastic) if necessary. Thanks in advance
The reason you would never want to use one of the "Universal" Toggles for Instrument Lights, Defrost Fan or Heater Fan is very simple, they usually are just Hi-Low-Off or Off-On but no Resister like a Car Type Switch to reduce the Speed or Power/Brightness, so you might as well bi-pass that switch as I said, use FULL Power and forget it.
The other reason is they look terrible, not as nice as Factory.
Studebaker switches ARE still available, so why not use them while they are.StudeRich
Looked through some of my "stuff". I have a NOS instrument dimmer for a '58 Pres IIRC, has a black knob and I think the resistor is a different value. I also have a '63-'64 Hawk dimmer switch, the white knob is almost gone and it's apart but all parts including the base with the resistor are there in a Ziplok. If you don't have any switch at all and you don't mind performing a marriage and some painting, that would work fine for you. I've jumped through a LOT more hoops creating impossible-to-find items from parts and pieces.....
