Supercharged '56 Packard
Looks like a home made kit, and it won't "fly", not with with the smaller Packard engine in a 4000 pound car.
JDP/Maryland
63 R2 SuperHawk (Caesar)
spent to date $54664,75
64 R2 GT (Sid)
spent to date $62,439.30
63 Lark 2 door
52 Starliner
51 Commander
39 Coupe express
39 Coupe express (rod)
JDP Maryland
JDP/Maryland
64 R2 GT (Sid)
63 Lark 2 door
52 Starliner
51 Commander
39 Coupe express
JDP Maryland
Certainly looks like a homemade piece. I gotta give him credit for getting it installed in there. There are a couple of things though:
The blower of course appears to be the SN60 as the snout is smaller, and has a double pulley setup. Overall the blower setup looks like it was pulled from an Avanti.
Among other things,I pray he sealed that other model Carter carb or used another model of sealed Carter carb, as the sealed 4 bbl Carter thats used picks up from the front and not the rear. [:O]1964 Studebaker Commander R2 clone
FWIW, I know the seller from another Packard forum and he is a very creative mechanic and fabbed the installation a couple of years ago. It will be interesting to see if the supercharger overcomes having a 320" in the Patrician.
thnx, jv.
PackardV8PackardV8
thnx, jv.
PackardV8PackardV8
Right in the written body of the ad it says that it is a SN60 Paxton from a '63 Avanti. It also appears to have a GM HEI distributor. At 320 cubes the Avanti SN60 is a little small, although it should give a good low rpm boost. It would be cool with its hood up at just about any cruise night because it would be so unexpected.
Thomas
Long time hot rodder
Packrat junk collector
'63 Avanti R2 4 speed
Thomas
It's my car, and yes, it flies, yes it's a 320, out of a 1955 Hudson Hornet. Yes, it has an HEI distibutor, it wasn't to easy to make, but it works excellent. The SN60 is out of a '63 Avanti, the carb's an Edelbrock, which according to VS57.com, doesn't need to be sealed at the boost levels I'm using. The blower bracket was made by Packard V8 Club members at the first Packard V8 Club meeting in Pahrump, Nv, in 2005. It's probably as close to professional manufacture as you can get, because the guy who built it from our mockup is a fabrication God!
Any questions on how to supercharge a Packard V8, just ask, as I can tell you anything you need to know.
Eric
Eric
