I need some for a motor. Dusty
Rocker Arms for 1964 v8 new
IIRC, the mid-'62-'64 are the same.
Having said that, in fifty-plus years, stuff has gotten swapped around. Make sure you and the seller know the difference. I've seen early engines come out of late cars, late engines with early rockers; engines with mixed early and late rockers.
jack vinesPackardV8
Originally posted by oilnsteel View PostWhat, pray tell, is the difference? How do you identify various ones?
Thanks, JT
Visually...the difference is -
Valve pad tips are oval = EARLY.
Valve pad tips are (more) round = LATE.
Material at the bottom of the rocker is round (has a full radius) = EARLY.
Material at the bottom of the rocker has a big heavy square pad = LATE.
A couple other small differences, that are harder to spot. The above are very easy to notice.
