I was looking in the archives and couldn't find the torque specs I need. I did check the shop manual, but want to double check torque specs. The Bellcrank pinch bolt - 60-65 ft lbs. Bellcrank bracket mounting bolt to front crossmember - 40-45 ft lb. Now, I also need torque specs for the 3 nuts/bolts that mount the steering box to the frame. Also, I had 3 washers that I "found" on the frame rail after I took the steering box bolts out. I assume that there was a washer between the frame and the steering box mounting bracket. Does this sound right? Thanks in advance.
Nate
Nate
