Advice on Changing 1941 Commander Land Cruiser U-Joints
  • Drive Shaft: Advice on Changing 1941 Commander Land Cruiser U-Joints
    Somewhere under the car there is a rattle so I was under there looking for it when I noticed that the front U-Joint is loose.
    I'll order 2 new U-Joints from Studebaker International. Do you recommend that I change the rear transmission seal (where the slip yoke goes in) also?
    Any special advice on changing these U-Joints.
    I've done lots of them on 1960's type cars and trucks but never on a 1940's.
    Any experience and wisdom are appreciated.
    Is it severely leaking?
    Brad Johnson,
    '56 Sky Hawk in process
      No. It doesn't seem to be leaking.
        Moving to Tech Talk.
          You might want to consider getting the shaft rebalanced to avoid any unwanted vibrations.
