I am doing a restoration on a 1965 sliding roof Wagonaire (P) body. I ordered and received from SASCO upper rubber door molding 136350 & 351. But it doesn't fit. If you can tell in the pictures, front corner and front edge going down the door from top to bottom seem to fit fine. The problem lies in the rest of the rubber molding. First there is a twist in the extrusion as its going across the top of the door, this is not a twist that can be un-twisted but built into the design?? Second problem is no square corner built into the molding to fit the rear upper square corner of the door? Thirdly it is also to short to then go around the window frame and onto the door (picture2)
I have tried every instillation direction, checked part for miss boxed to no solution. One interesting fact is in the factory parts manual 136350 & 351 fit a (Y) body, where a (P) body calls for molding 136358 & 359. SASCO says no stock and only use 136350 and nobody has had a problem.
Any ideas or guidance would be appreciated, Scott Hall
