The first of the Studebaker dealer repo signs are finished. Double sided 32" heavy 12 gauge steel just like factory. Epoxy primer and painted with base clear and buffed before decal installed so this can be mounted outside for years and looks almost like porcelain. Not like cheap China built thin tin repo's that bends with your fingers. Made in the USA. Thinking $350. plus shipping.
first of studebaker dealer signs done
WOW! That's sweet! (and big!)
Sounds good, and looks Great, but unless you can get the Mfg. costs down more, it's a hard sell at over $100.00 for most Club Members (75% CASO).
I guess we need to remember that "Made in USA" in Today's World is NOT cheap!StudeRich
Studegary I know that but then you run into shipping problems. I was talking about the thickness of the metal. AS far as finding a way to get them under $100 the cost of metal,paint, decal and labor to build the sign runs more then that. These are a heavy duty sign not a thin one sided China repo.
swvalcon, that looks like good quality, but you'll probably have a hard time getting that much money for a sign that's already reproduced and readily available, regardless of how well it's made.
Originally posted by Silverplate View PostHanging on the wall they will all look pretty much the same.
BTW, I promised RQ that I wouldn't make any to sell. He can supply them on various substrates if you want a printed version, though.
Originally posted by 2R5 View PostThe 32 in ones were the red type .
IIRC, the one pictured is colored the same as the one that I sold you and that was 42". Am I correct on that?Gary L.
Originally posted by swvalcon View Postthe first of the studebaker dealer repo signs are finished. Double sided 32" heavy 12 gauge steel just like factory. Epoxy primer and painted with base clear and buffed before decal installed so this can be mounted outside for years and looks almost like porcelain. Not like cheap china built thin tin repo's that bends with your fingers. Made in the usa. Thinking $350. Plus shipping.
The sign image posted by Matthew is from 1916 and is a wagon wheel. I have over a dozen different original signs that I have created authentic graphics for that can be made in the original size or larger or smaller as needed. Price done on foam board in the $100 to $150 range.Richard Quinn
Originally posted by studegary View PostBy "red type", do you mean something different from what was pictured in post #1? I am thinking of the type that is sort of reddish/brown,
IIRC, the one pictured is colored the same as the one that I sold you and that was 42". Am I correct on that?sigpic
