I would like to know if there are any fitment problems with installing 53/54 "C" coupe front fenders and doors on a 60 or 61 "C" Hawk and would a Packard Hawk fiberglass front nose fit up to the 53/54 front fenders?
Fender and Door Swap
For the second part - the front of the fenders would have to be altered/reworked for the nose to fit.
For the first part - that depends on inner fender use or are you only referring to the outer fender?Gary L.
Originally posted by studebacher View PostStudegary, I sent you a P.M. explaining what I'm trying to do and requesting your advice. Thanks.
The 1953-1956 C body doors will fit and give you the swoop. The 1956 is a slightly shorter swoop.
All of the 1953-1964 C/K fenders have the crease/line that leads into the swoop. You do not need to change your 1960 fenders (inner or outer) for this.
If you keep your 1960 fenders, you do not have to worry about inners.
Studebaker modified the lower front of K fenders for the Packard Hawk. This allows the nose piece to fit nearly flush. This modification will be easier on a steel fender than a fiberglass replacement (IMO). Somone that has or is redoing a Packard Hawk should be able to give you pictures and dimensions for this fender modification.Gary L.
Interesting Gary, I had no idea that "56" had a shorter rear portion of the scallop than all the others.just how noticeable is this,or do You really need to measure.
Originally posted by studegary View PostI attempted to reply to your PM twice and it would not go through. I will now attempt to reply to your PM here.
Studebaker modified the lower front of K fenders for the Packard Hawk. This allows the nose piece to fit nearly flush. This modification will be easier on a steel fender than a fiberglass replacement (IMO). Somone that has or is redoing a Packard Hawk should be able to give you pictures and dimensions for this fender modification.Joseph R. Zeiger
Originally posted by 63t-cab View PostInteresting Gary, I had no idea that "56" had a shorter rear portion of the scallop than all the others.just how noticeable is this,or do You really need to measure.
Thanks Matt, always learning some thing new.hard to believe Studebaker would spend money on some thing that really didn't need changing .I wonder how many doors were changed over the Years,and left Cars with mixed matched sets "and no one even knew"
Originally posted by mbstude View PostFrank Ambrogio just recently published an article on this.
http://www.1956goldenhawk.com/newslpdf/56jon081.pdfJoseph R. Zeiger
Originally posted by 63t-cab View PostThanks Matt, always learning some thing new.hard to believe Studebaker would spend money on some thing that really didn't need changing .I wonder how many doors were changed over the Years,and left Cars with mixed matched sets "and no one even knew"
The next year, a bigger change was made to the doors that eliminated the swoop.Gary L.
So I guess they felt the lower moulding needed to be that wide,if made more narrow maybe it would have been effective and missed the swoop ? interesting about this stuff.
Originally posted by studegary View PostBut it was felt that this change was needed. The swoop was shortened up to clear the higher side moulding. The side moulding was brought up from the rocker panel to the doors to make the car appear lower.
The next year, a bigger change was made to the doors that eliminated the swoop.Joseph R. Zeiger
Originally posted by 63t-cab View PostSo I guess they felt the lower moulding needed to be that wide,if made more narrow maybe it would have been effective and missed the swoop ? interesting about this stuff.
As an aside, Bob personally made the mold and molded the small fins for his own 1954 Starliner (they are metal, not fiberglass like on a 1956 Golden Hawk).Gary L.
