Of all the mean, nasty jobs I've done on cars over the years, replacing the spring bushings on my '63 Wagonaire Standard has to rank near the top of the list. I don't have a lift, so the car is up on jack stands, and I've had to do most of this work on my back under the dirty car. [If I EVER do another major project, I'm going to have someone else power wash and sandblast the bottom FIRST.]
On the first bushing, I tried the thing with pulling them out using threaded rod and a big plug - forget it! Then, I went delicately with a hammer and cold chisel, learned to cut through the outer tube to get the %$#*& things loose. It took hours! The second one I used a hacksaw blade set backwards in the frame to cut through the shell, but it was still tough to drive the shell out. Then I went and bought an air chisel. Why did I never own one before? Even then, the fat bushings in the front spring eyes needed to be set on fire with the MAPP torch to get the inner tube and rubber out before I could use the air chisel on it. [Yes, the gas tank is out of the car.] Six bushings, skinned knuckles, aching muscles, and countless hours - and the car doesn't LOOK any different. Anyway, it's finally done and I can move on to some other job.
What's the task that you hate most when working on Studebakers?
Dartmouth, Mass.
'48 M5
'65 Wagonaire Commander
Dartmouth, Mass.
'48 M5
