57,58 Packard water pumps,are they different than
  • 57,58 Packard water pumps,are they different than
    The rest of the cars ? "as in shaft/hub location - pulley surface"
    Joseph R. Zeiger
    No, they shouldn't be Joe.
      Thanks Ed, ok so are any of these pumps different in this respect ? Avanti, certain Trucks maybe?
      Joseph R. Zeiger
        Yep, there are a few flavors. standard V8, HD V8, Avanti pump come to mind.
        JDP Maryland
          The centering "Nub", Hub Center is twice as Long on an Avanti.
          BOTH the Avanti AND the H.D. for A/C and Supercharged Lark/Hawk, have three gussets reinforcing the Bearing Housing portion of the Pump.
          The H.D. has a Standard V8 short Hub "Nose".
            My 1957 Packard water pump looks to be the same as a 1962 Hawk 289 water pump. Only two I have to compare.
            Lt. Col. Jimmy Doolittle
              Rich, this info some how has Me confused . the pump I have has no webs "3" on the housing,but does have the "about 1/2" nub facing the radiator side.in other words the surface that mates the pulley is off set all the way to one end of the hub.the standard duty that came off the engine has the pulley surface about centered on the hub.maybe I need to find out what for spacers are available from SI,inhopes of maybe leaving this pump on and not back tracking again ?
              Joseph R. Zeiger
