I have a 54 Champion sedan that had a perfect running 6 but I needed a challenge, I pulled the 6 and inserted in its place a 259 Lark V8. The front motor mounts are the same, but I decided to move the engine back one inch to allow more clearance for the fan. I mocked up plywood mounts to fit then made them out of metal. With the engine set back one inch, allowed the bolts on the rear mount to sit on center on the batwing where I had to drill two holes to fit. I converted the 12 volt system to 6 volts and it starts very easily, usually 2 - 3 revs.
The starter motor was a challenge I had to order a generic drive from a jobber that lists the drives by specs, not make and model. I used a 6 volt starter with a 12 volt snout with the generic drive. I had to machine the armature shaft to fit the drive. I have to make a second starter for a spare. I bought three 259s to get enough parts. The first one was missing the bell housing, the second one had the bell housing, but no transmission, the third one was complete with transmission (late T86 w/OD). The 2 piece drive shaft was replaced with the single shaft out of the Lark. The rear universal fit but the shaft had to be lengthened 4.5 inches. I have only static tested so far. I have an issue with heat riser, it won't open, it is completely free when moved by hand. Perhaps the spring is too tight. David
