The plastic inserts on the fender spears for my '55 Pres are vulnerable to having the mounting tabs broken due to fender leaners. A partial solution might be to stuff some foam between the insert and the fender to provide at least some support. Any other Suggestions???
Any suggestions on protecting the plastic fender spear inserts?
Body / Glass: Any suggestions on protecting the plastic fender spear inserts?
American iron, real old school
With two tone paint, it sure is cool
Its got 8 cylinders and uses them all
With an overdrive that just won't stall
With a 4 barrel carb and dual exhausts
With 4.23 gears it can really get lost
Its got safety belts and I ain't scared
The brakes are good and the tires are fair.
Tried to sell her, but got no taker
I"ll just keep driving my StudebakerTags: None
The best way is to keep your car away from any fender leaners, maybe you need a BIGGER Shotgun!
I would think Road Rash would be a lot bigger threat.StudeRich
Originally posted by greyben View PostThe plastic inserts on the fender spears for my '55 Pres are vulnerable to having the mounting tabs broken due to fender leaners. A partial solution might be to stuff some foam between the insert and the fender to provide at least some support. Any other Suggestions???Jerry Forrester
Forrester's Chrome
Douglasville, Georgia
The reinforcement bar sounds obvious and logical. Thanks!American iron, real old school
