Guys - Would high pressure CV joint grease be okay in a cleaned and degreased steering box - or is there something better? Thanks!
Grease recommendation
I'd think straight grease would make it steer real stiff in cold weather. Have used STP a few times, in a pinch. Best to install a modern seal on the pit arm shaft, when feasible, then you can run gear oil, per OEM specs. The above are substitutes to make do till then, AFAIC.
Originally posted by tomnoller View PostGuys - Would high pressure CV joint grease be okay in a cleaned and degreased steering box - or is there something better? Thanks!
(If you don' know, exactly what size wrench fits the fill plug?) BPWe've got to quit saying, "How stupid can you be?" Too many people are taking it as a challenge.
SI sells a grease/lubricant for steering boxes. My '55 original box would not hold fluid more than 30 mins. I put a grease fitting on a replacement plug and used regular grease to grease the steering box. As far as cold weather, the car is not driven in cold weather (ice, snow and salt).sigpic
55 President Deluxe
64 Commander
66 Cruiser
37 Oldsmobile F37 4 Door
steering boxes are one of the most neglected parts on our cars. Your better off rebuilding the box with fresh bushings and seals then run the correct lubricant.
53 2R6 289 5SpdOD (driver)
57 SH (project)
60 Lark VIII 2dr sd (driver)
Originally posted by tomnoller View PostGuys - Would high pressure CV joint grease be okay in a cleaned and degreased steering box - or is there something better? Thanks!Bo
The BIG issue here is which Year and make Steering Gear does it have?
Saginaw recirculating ball type '61-'66 Lark and Lark Type Boxes use ordinary non-EP Chassis Grease.
The recommended Fluid for Ross Boxes was 90 or 140 Wt. OIL, but they leak so badly that many now use the Semi-fluid Grease.Last edited by StudeRich; 08-03-2015, 11:32 AM.StudeRich
Originally posted by bill matwijec View PostNot to wander from the original question but how do I tell which steering box I have ?( 65 commander)StudeRich
