Avanti Mystery Pieces
They look like part of the gutter trim.
They screw onto the front pillar where the front quarter window closes ie between the rubber and the body and over the windscreen side trim.
There should be 2 long pieces as well that screw to the underside of the outer roof which joint these pieces and run across the top of the door and rear quarter window. It acts like a gutter and catches the water running of the roof.
Either way (mine or Gunlingers) look in that front post area for there placement.
pbLast edited by 63r2; 08-01-2015, 03:08 PM.
pb
To continue with Rich's thought,.....I've seen many odd pieces of Avanti rain gutter trim floating around at swap meets over the years....and I think that has to do with the Studebaker 'early Avanti' retrofit rain gutter program. Kits that were released but never actually installed on a car.
The hard part to find is the little corner pieces that join the top gutters to the "A" pillar pieces.Bez Auto Alchemy
Originally posted by bezhawk View PostThe hard part to find is the little corner pieces that join the top gutters to the "A" pillar pieces.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
