Hello together
I need your help. The existing speedometer cable has a wrong diameter now - it is too loose (with 22mm/0.86in) now - this was used with a 61 flight-o-matic with long tailshaft. Now as I am installing a 1957 Flight-o-matic Golden Hawk transmission(with short tailshaft), the existing speedo cable no longer seems to fit(because of diameter). The gear housing on the 57 Flight-o-matic transmission now seems to need one with 25mm/0.98in).
I saw in the catalog of Studebaker international, it shows a cable 1544768, but says "58 Sedan + Hawk with automatic transmission". It looks the same as my current cable - but I would need to know the diameter of it. There is a 7 teeth drive gear in the flight-o-matic transmission and I use a 21 teeth pinion gear (because of KP/H).
I want to make sure I am buying the right thing. Could somebody please help me in finding the right cable? It doesn't matter if it would be an original cable or a reproduction new one.
I also assume that I could reuse the 21 tooth pinion gear (there all seem to be the same, right?)
for example would this speedo cable work? http://www.ebay.com/itm/NORS-Speedom...c8ea59&vxp=mtr
But I will need to know the correct diameter, anyway.
Thank you very much in advance for advice.
Have a good weekend.
Ruedi, Switzerland
Ruedi, Switzerland
