Just something that might be helpful to someone.
I discovered that when I took the two "obvious" bolts out of the door hinges on my 50 that I still could not get them out of the the body. After a while I considered the "bigger hammer" procedure but decided to not use brute force as I have found through experience that this usually results in my ruining something and costs me both time and money. I went on to other things and a few days later while searching for something else inside the area between the door post and the front fender I found the end of a bolt. Alas! and Ta Da!, the source of my problem was found, "hidden" deep inside the door hinge socket. I removed it and the hinge assembly came right out!
1950 2 timer
1950 2 timer
