View Full Version : Engine: Motor mnt. prep.
Jerry Forrester
07-15-2015, 06:21 PM
The smaller rubber biscuit goes underneath the motor mnt. frame bracket and the center of it protrudes up through the bracket.
https://i.imgur.com/417vWvM.jpg
The hole for the RHC car mounts must be plugged.
https://i.imgur.com/afxZqOc.jpg
The holes for the LHC car motor mnts. must be opened up to accept the lower TD biscuits.
https://i.imgur.com/2OGHkKI.jpg
https://i.imgur.com/Tdw2aWx.jpg
Colgate Studebaker
07-16-2015, 01:55 PM
Jerry, does this new mount lower the engine some, sort of like the R3 motor mounts? Getting all the hood clearance possible is always a good thing. Bill
Jerry Forrester
07-16-2015, 02:54 PM
'fraid not.
wlfrench
07-18-2015, 07:07 PM
Just finished doing the same thing. Took my 62 GT off the road for a week and did it in my driveway. If ever you want to try your patience, taking those lower brackets off while laying on your back on a gravel driveway is the job for you.45797
07-18-2015, 07:16 PM
Looks like you did it the "easy way" Wayne, just installed '51-'52 Engine Mount Brackets and Stude. Mounts. :!:
It's too much work welding up holes etc. especially if you do not do welding.
wlfrench
07-19-2015, 04:08 PM
Looks like you did it the "easy way" Wayne, :lol:
I remember laying there under my GT, after getting the first bolt off the lower bracket, thinking, what have I got myself into and how am I going to ever get these bolts back on.:confused: It was very hard to reach the bolt heads with the longest wrench I had and every time I got it on the bolt it would fall off as soon as I tried to loosen the nut on top. This is what I came up with. I took an old 1/2"-9/16" box wrench and cut off the 1/2" side then added a long socket extension and a couple of small hose clamps to get this. 45821 Then I epoxied a small magnet to one side of the 9/16" box end to hold onto the bolt head. 45820
45822
After that things went a little bit quicker.
