Hey all,
New to the forum so I thought I would say hello, ask about an engine ID and get any thoughts / advise you guys may have on the project. I have a chance to buy what I've been told is a 1950 1/2 ton pickup for $2500. The guy who owns it bought it back from the north west somewhere, it had set for years behind the previous owners barn, but he's out of town so I can't get anymore details for the time being. He says he has everything for it, but the cab floors, supports, corners and door bottoms are bad so the interior is stripped out so the serial number plates have been taken off. I've been doing a ton of reading about pretty much everything I can learn so I know what I am up against to try to get it on the road and update things down the line.
This will be my first attempt at fixing up a non running vehicle, so I'm hoping I'm up for the task lol. The motor has the pullys and carb pulled off but has some stuff still hooked up so I'm not sure if it's the original motor or not but the engine ID number is 4r31460. From what I've seen looking at the engine ID lists it comes up as late 40's early 50's 2r commercial 245ci. Just want to make sure I'm reading it right, if so would that mean it's a commander engine? And if so, if it's the original motor does that mean the truck will be a 2R6?
The truck has a solid body and frame other then the cab, it has a 3 speed with overdrive, and will need a driver side windshield and both side windows. He also has a 3/4 ton cab with fenders and hood but no glass ( great floors and doors) and a 2R16a with complete running gear, 4 speed tranny and 2 speed rear but the floor is starting to go and the bottom of the doors are bad. It looks like the engine would be easy to get running as it's all complete, he had bought it originally for the cab and spare parts but unfortunately it has set to long, it's interior is gone. I can buy them for parts for $500 each, so that seems like a pretty good deal since I can sell the left over parts when I'm done.
From what I've read the 2r16a would also have a commander motor, so then would I just be able to swap it over, and if so should I be better off staying with the 3 speed with overdrive or bringing over the 4 speed with it?
Sorry about the long winded not so focused post but my mind has been kinda overloaded since I started researching everything Studebaker????. Down the line my plans would be to convert the front end to disk brakes and drop it some, I really like the look of Sdude's with the new front suspension.
Thanks, Troy
Thanks, Troy
