Okay, I give up. Need to replace the rear drums on my Avanti to pass brake test, mine too far beyond .080 to get the linings to stop it. New ones are out of the question, as they will only be on the car till I can afford a rear end swap which will eliminate them completely. Prefer some in driving distance from southern Delaware, too expensive to ship. If this were 2-6 years ago I could get them through the swap site, but that was then and this is now. Any offers or suggestions on a source.
Avanti Rear Drums needed Used???
What year Avanti? The rear brakes changed sometime in the early '70s.
Best bet to find good used would be Myer's Studebaker, Nostalgic Motors or maybe Studebaker International. Some of the other vendors that advertise in Turning Wheels might be able to help as well.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
Originally posted by Gunslinger View PostWhat year Avanti? The rear brakes changed sometime in the early '70s.
Therein lies the distance problem. Most have new ones they would like to sell, at $200.00 or $150.00 each without hubs, again this is a temporary solution for me. Even thought of finding new super thick relined shoes, like a prior owner did to get by, but that goes against my nature of doing it "right". Thanks for the suggestion though--maybe some one who has done a Turner rear disk conversion?
If any of that is doable for you, I'll dig them out and measure them.
John
Originally posted by JLB View PostI have some 11" drums. Are you going to the meet in St Louis? Or know someone in your area that is going that could bring them back for you?
John
I'll have some at the meet.Bez Auto Alchemy
Originally posted by bezhawk View PostI'll have some at the meet.
Originally posted by gordr View PostRemember that Greyhound still carries freight.
I don't know why everybody nowadays makes drum brakes a mystery. If the drums are worn then we used to get the shoes with oversize linings. Be careful not to let the linings get too worn or not to overheat and warp the brake drums and you were good to go. Back then when new or relined brake shoes were installed they were arced or fitted to the drums. I have one of the measuring tools for doing this, the inside part measuring the inner drum and the outside measuring the outside of the brake shoes. It is also useful to figure out how thick to make your oversize linings. In the 60-70's I was regularly driving at 70-90mph with cars that had 10* Delco-Remy drum brake systems and had no problem stopping. I guess today everybody wants an complicated and expensive solution to a simple problem.
Originally posted by Mikado282 View PostI don't know why everybody nowadays makes drum brakes a mystery. If the drums are worn then we used to get the shoes with oversize linings. Be careful not to let the linings get too worn or not to overheat and warp the brake drums and you were good to go. Back then when new or relined brake shoes were installed they were arced or fitted to the drums. I have one of the measuring tools for doing this, the inside part measuring the inner drum and the outside measuring the outside of the brake shoes. It is also useful to figure out how thick to make your oversize linings. In the 60-70's I was regularly driving at 70-90mph with cars that had 10* Delco-Remy drum brake systems and had no problem stopping. I guess today everybody wants an complicated and expensive solution to a simple problem.
Originally posted by karterfred88 View PostWhere can you get oversize linings done? No relining facilities local that I can find, any recommendations?
