On my 63 Avanti, I've been trying to adjust the rear brakes with the eccentrics but can't seem to get them tight enough to get the right rear drum adjustment. The eccentric bolts are brand new from SI, linings brand new from another vendor, drums measure okay, new 3/4" correct wheel cylinders, nothing looks worn at the pivots. I can completely turn them without ever tightening them up enough in any position to get the rears to work right. Any tricks I could try? Most likely it's a combination of too thin new lining material and maxed out drum diameter, or is it possible the eccentrics don't have enough offset? I have to pass a braking test here in Delaware to get plates and right now it won't lock up the rears enough to show maximum braking effort on their test bench. the front disks are fine at 100% but the rears are at 50% and 70% meaning they aren't getting enough contact or pressure. The system is split with a 1 1/8" master matching the original design specs from Bendix. Never having been able to drive it till now, due to assorted mechanical issues, I don't have a reference as to how well it should stop. Although I had a 63 GT with disks in 1966 and drove my dad's Avanti back then, that was a long time ago, and of course I've been spoiled by todays brakes for many years. Other than adjusting the hand brake cables to take up some of the room--any ideas. I don't want to buy new drums and another set of linings as I eventually want to convert to rear disks, and I would be wasting $500.00 for a temp fix. Putting on the Turner kit on the rear only and leaving the fronts doesn't seem like a good idea either.
Looking for Ideas, adjusters out of range?
You WILL have to remove the drums to figure this one out, so take some pics... I just had a scenario exactly the opposite... too much lining and the wrong shoe core and I couldn't get the drums on at all.. Until...
I figured out the brakes (box) were labeled PAB53, but the steel shoe cores were stamped B173. This made the slot where the E-brake lever fits, too shallow and the shoe assembly couldn't collapse enough to get inside the drums .. but a little voodoo with a grinder and a file was invoked and all is well.The B53 and B173 shoes both fit the rear Disk brake cars, but this subtle difference drove me up a wall.
Can you effectively apply the handbrake on your car?64 GT Hawk (K7)
1970 Avanti (R3)
Originally posted by 64V-K7 View PostCan you effectively apply the handbrake on your car?Last edited by karterfred88; 07-09-2015, 07:59 AM.
What about the fixed anchor at the bottom of the backing plate? Is it OK, and are the heels of the shoes that ride there OK? Will the rear brakes grab if you pump the pedal? If it was just a case of undersized shoes, pumping the brakes should make them apply, or, worst-case, pop the pistons out of the rear wheel cylinders, since there are no stops. I wonder if your rear brake lines need bleeding, still. Other than that, it sure sounds like your shoes are assembled on the wrong cores.Gord Richmond, within Weasel range of the Alberta Badlands
Well getting ready to "pop" the drums to see what it is I installed. Here's images of what came out 2 years ago. Note-one side was riveted linings one shoe less lining than the other, one side bonded, same length each shoe, both had 2 different shoes- looking at the area going into the wheel cylinder. One side a thin long nose, one a thick nose. The bonded set, on one shoe was the number 48154 on the riveted set one shoe labeled 313548. The bonded linings were much thicker on one shoe than the other and the thickness of both greater than the riveted ones. Any ideas which, if any was the correct shoe-shoes for my Avanti? A picture of a correct pair would help to compare to my installed ones to see what I need to do to fix it right. None of the areas marked in red are the same between the two and not even consistent on each set. The parts book shows different shoes for trailing and leading but no details showing what actual differences were. I suspect the lining coverage on the trailing and leading shoes were different coverage of the steel shoe, but were there other differences in the steel shoes themselves front and rear placement?
Footnote: They were all soaked in brake fluid from blown wheel cylinder, a lot cleaner looking now.Last edited by karterfred88; 07-12-2015, 09:14 AM.
Don't know if this is your issue but, back in the day working on a brand x I found a very worn brake drum on one side with oversized brake shoes on that side.
No adjustment there either untill brake drum was replaced.sigpic1957 Packard Clipper Country Sedan
Lt. Col. Jimmy Doolittle
Originally posted by 57pack View PostDon't know if this is your issue but, back in the day working on a brand x I found a very worn brake drum on one side with oversized brake shoes on that side.
It IS your Car I understand, but here is a better option for you.
Do not get all wrapped up in the idea that all Cars NEED Rear Disc Brakes!
Absolutely NOT NECESSARY, what I would do is, rebuild the Rear Brakes with New 11 Inch Finned Drums NOW, and install the Turner Front Discs. when you can afford it, your Avanti will stop as fast as you will ever need. Using the stock rear setup does not require an equalizer valve, residual valves or anything to run the Turner Front Discs.
Once the brakes are locked, you are at the mercy of the Tires to stop you, and you can't stop any faster than they allow.StudeRich
Originally posted by StudeRich View PostIt IS your Car I understand, but here is a better option for you.
3.73 and down, new ring and pinion, bearings seals and substituting flanged for tapered axles, together I'm up over $1800.00 with labor (I'm not up to heavy duty rear end work and the tools needed) , then the prospect of paying another $400.00+ down the road if I need new drums again, it becomes a "no-brainer" to swap the rear end assembly, put in disks at the same time, and get replacement parts--like new rotors for under $50.00 each! I have no need for disk brakes on the rear really, but since I'm stuck right now at $400.00 plus shipping for something that only partially fixes my problem. Verses a used Ford 8.8 with disk brakes and internal drum style parking brakes, a usable rear ratio, with all new brake parts, cost of welding new spring perches and traction bar mounts for around $600.00 total it makes it hard to spend $400.00 now--. I'd be happy with putting on some slightly used drums if anyone near Delaware had some for sale--inexpensively--as a stop gap measure.
Originally posted by karterfred88 View PostI know. But, driving this car with a 4.09 rear makes it worthless over 45 MPH. If I add the cost of brake drums, new differential carrier for
Originally posted by sweetolbob View PostWell said, couple that with a dual M/C and proportioning valve and you have a winner on your hands. Bob
Rather than start a new thread, first thanks to those that offered to help but weren't able to. I'm going a different direction by trying some non-Stude drums and adapting as necessary as I don't plan on keeping them on there anyway. As an aside, before putting things together, I noticed the linings, sold to me from a reputable vendor, were incorrectly relined (lining bonded to bottom 2/3 of shoe rather than top 2/3). Before shoving this thing out of the garage again, does anyone have a lead on a vendor selling them done correctly?
Some Shoes come with the short Shoe fully Lined, some short in the center, some at the bottom, some at the Top, no one has noticed any difference in braking. The Reliners of today do not know or care which is Engineering "Correct".StudeRich
Originally posted by StudeRich View PostSome Shoes come with the short Shoe fully Lined, some short in the center, some at the bottom, some at the Top, no one has noticed any difference in braking. The Reliners of today do not know or care which is Engineering "Correct".
