I know some here are using them,I'm curious what the muffler" "body" dimensions are - width,height,and length.I'm not too concerned about the inlet/outlet pipe connections.
Studebakers running Flo Masters.
Originally posted by 63t-cab View PostI know some here are using them,I'm curious what the muffler" "body" dimensions are - width,height,and length.I'm not too concerned about the inlet/outlet pipe connections.
All that said, the Flowmasters I've used (including their less aggressive 50 series) have a horrendous drone right in the middle of the normal driving range (1,900 to 2,600 RPM). The sound is like a form of acoustic torture that follows the car just about everywhere it goes.'64 Lark Type, powered by '85 Corvette L-98 (carburetor), 700R4, - CASO to the Max.
I been looking for a muffler that is quiet but flows well. By quiet i mean quiet stock mufflers with a 2" to 2 1/4 inlet and outlet. I want them for a 54 K, and my 64 Commander.101st Airborne Div. 326 Engineers Ft Campbell Ky.
With any type of muffler, you have to be careful for resonance issues.
Last set of Flowmasters I ran had a great sound.
Mellow, and quiet...as long as I drove it quiet.
But (duals with no x-cross) there was a nasty resonance at cruising rpm that was almost painful.
The answer? Extended the tail pipe tips about 1".
Completely changed the frequency, and killed the resonance at that rpm.
All I am saying is don't be afraid to try something, but don't automatically toss it out if it needs some 'tuning'...HTIH (Hope The Info Helps)
Flowmaster makes just about any size & style muffler size you could want so go to their website and search for whatever size you think you need. http://www.flowmastermufflers.com/?page_id=13118 I have MagnaFlow SS mufflers on my GT and they work great, same lifetime guarantee and no drumming noises. Mine are: body length 14", inlet to outlet length 20", 2 1/4" inlet is center body, 2 1/4" outlet is offset and cross section is 5" X 8" oval. Pretty sure Flowmaster has the same size.
Some years ago when the Plain Brown Wrapper needed mufflers for the Pure Stock Drags, I asked organizer Dan Jensen what the competitors were using. He said many of the fastest cars were using DynoMax Ultra Flo mufflers. They are straight-through design, but they are not especially loud. I don't particularly want really loud mufflers, and I love the sound of the DynoMax. They make a nice rumble at idle and in normal driving, but they "bark" nicely when you get on it. They don't seem to have any undesirable resonances, but of course many variables go into whether or not a car has those, including crossover pipes, diameter of exhaust system, exact lengths, etc. The Wrapper has certainly performed well on those mufflers. I like them so much I just bought another pair for my '63 R2 Lark.
Georgegeorge krem
I've used 2 chamber Flow Masters on my 289 4 speed 54 Coupe for decades. I love the sound. It does have a resonance at certain speeds. My car does not have carpets, nor door panels, nor headliner, nor radio, so it does get loud. Its been this way for many many years and I never get tired of the sound. When I make a drive for any significant distance, I use foam earplugs. It keeps the droning from making my head swim. But for all the in town driving, I've always loved to hear the "music" of that exhaust note. I've pulled into car shows and have had numerous people ask if I was running a big block Chevy.sals54
During the first few years of the dual exhaust era - mid-50s to early '60s, Ford and GM each had an exhaust design strategy to eliminate the drone/resonance which V8s develop at cruising RPM. Ford used a crossover H-pipe connecting the two head pipes. GM ran separate pipes and mufflers and added two rear canisters behind the rear axle. Today, because of the cost of catalytic converters, most vehicles with two tailpipes are actually a single muffler behind the rear axle.
jack vinesPackardV8
Originally posted by DEEPNHOCK View Post... But (duals with no x-cross) there was a nasty resonance at cruising rpm that was almost painful. The answer? Extended the tail pipe tips about 1". Completely changed the frequency, and killed the resonance at that rpm. All I am saying is don't be afraid to try something, but don't automatically toss it out if it needs some 'tuning'...
As best I could tell the resonance was emanating from within the Flowmaster, across the air gap and into the car structure. So, anything down stream had no effect. For the record this was a fully carpeted/upholstered car that prior to the exhaust change was about the quietest 70's era car I had driven in.'64 Lark Type, powered by '85 Corvette L-98 (carburetor), 700R4, - CASO to the Max.
