I'm pulling my 259 out of my 1964 Wagonaire to replace the seals and frost plugs. It's almost ready to come out, BUT, how do you disconnect the speedo cable from the trans. The X in the frame is under all that stuff. I'm thinking, if I disconnect the driveshaft back by the rear end, then pull the motor and trans forward past the X in the frame, then cable can be disconnected . Any advice would be helpful. I need to get this done before the end of August.
Steve
Steve
