I've sort of turned the corner on my current project, and I'm starting to re-assemble the front suspension on my 51 Commander. I've got a question about installing the thrust bearing on the kingpin. Is there a right way and a wrong way for the bearing to face? The bearing has what you might call an inside piece, and an outside piece. The outside piece has the bearing numbers stamped on it, and is sort of a cup-shaped piece that contains the rest of the bearing. Should the face with the numbers go up or down on the kingpin? From the drawing in the parts catalog, it looks to me like the numbers should go down, toward the steering knuckle. Maybe it really doesn't matter, but I don't expect to have this disassembled again for a long time.
Jim Beckman
Leonardo, NJ
1951 Commander Starlight
Jim Beckman
Leonardo, NJ
