View Full Version : Clutch/Torque Converter: Clutch needed for a 55 259
jbishop
06-08-2015, 08:57 AM
I am getting close to finally dropping the engine in the car and need to get the clutch installed.
I thought I had one in a box but I was wrong and have no point of reference to order a new one.
Does anyone know what clutch I can order to work with the factory pressure plate? Is it a 10" 6 spline? That's what I have on memory for some reason.
Please let me know any help will be appreciated.
Thank you,
Jared
doofus
06-08-2015, 09:41 AM
IMS 1 1/8 10 spline sticks in my mind, after the VA finishes with me i'll put on work clothes and go measure one for you. do you have a pressure plate? the 10in can be sorted from the 10.5 by looking at the perimeter of the pressure plate disc, the 10.5 is scalloped at the bolt holes. Later Doofus
jbishop
06-08-2015, 09:50 AM
I do have a pressure plate but I am at work and can't remember what it looks like. Thank you for that information! Its a huge help.
doofus
06-08-2015, 10:17 AM
Yes 1 1/8- 10 spline is correct,(I have gone to VA smelling of old grease and rust before) measure pressure plate clamping surface OD for disc dia. Luck Doofus
jbishop
06-08-2015, 10:22 AM
Great thanks! If anyone else chimes in with that measurement that would be great, otherwise I will measure when I get home.
06-08-2015, 11:38 AM
1-1/8" x 10 spline is literally one of the most common clutch disc and pressure plates ever made. Most US car and truck manufacturers used them in 10", 10.5" and 11" diameters.
jack vines
JoeHall
06-08-2015, 04:01 PM
DO an archive search here, as much has been written on clutches. Whatever you do, do not go with HD version of which ever one you choose, but that's in the archives too.
Joe H
63t-cab
06-08-2015, 07:26 PM
Jared, I sent You a PM. "blue bar upper right corner"
jbishop
06-09-2015, 08:35 AM
Thanks for the info and replies everyone!
