I'm a novice and would like advice. I have a 56 Sky Hawk that is pretty basic but solid. Would I be able to use the power brake set up and power steering set up from a 60 Hawk to upgrade my 56?
Hawk parts additions
Use the Mustang pitman arm ball and then you can mount the Studebaker power steering setup to it. No good reason on earth why it HAS to be the peened over ball on a Stude pitman arm when you can BOLT on something that will work.Bez Auto Alchemy
Originally posted by bezhawk View PostUse the Mustang pitman arm ball and then you can mount the Studebaker power steering setup to it. No good reason on earth why it HAS to be the peened over ball on a Stude pitman arm when you can BOLT on something that will work.
You just can't drill out the peened one on the permanent type setups. The hole HAS to be the same taper. The bolt in ones use the same taper as tie rod ends......seventeen degrees IIRC.Bez Auto Alchemy
