I relocated the voltage regulator on my 1963 Avanti R2 when I installed a dual-chamber master cylinder and a different brake booster. To hold the regulator in its new location, I drilled though the fender apron and installed nut-serts. Now here is the strange part. When I was checking grounds on the regulator, I discovered that the nut-serts are grounded. (Yes, I removed everything so that the nut-serts were isolated from any parts other than the apron.) A continuity test revealed that the nut-serts were connected electrically. That seemed weird to me so I got out a strong magnet and found that the magnet is attracted to the fender apron over much of its surface aft of the battery box. The magnet was not strongly attracted to the apron, but enough to overcome gravity on some of the less steeply slanted surfaces. I checked other metal parts that are attached to the apron and found that they, too, are at the ground state. This was a BIG surprise. Is there a metal screen or fabric within the fender apron?
Avanti Fender Apron
No wire in the construction. Only the Packard Hawk hood had screening in the fiberglass. That was for radio spark interference.
Avantis had ground wires connected to the regulator, and most every thing that had power going to it.
Every bolt on the inner fenders had a metal nut plate riveted on the back side. That is what your picking up with your magnet.Bez Auto Alchemy
Originally posted by bezhawk View PostNo wire in the construction. Only the Packard Hawk hood had screening in the fiberglass. That was for radio spark interference.
Originally posted by rkapteyn View PostSet your meter to the lowest ohm setting and measure the actual resistance to ground.If it is set to the highest range it will read even a moisture layer.
Originally posted by karterfred88 View PostThat must be one super strong magnet!! I can't get one to stick to the apron even over one of the riveted in supports on mine !! You must have a one-off iron infused apron assembly!!
What type of paint/color is on the apron?? Maybe something in the coating is showing up.
