View Full Version : Joe Flannery Report from May 2015 Musclepalooza XXI
BobPalma
06-02-2015, 02:47 PM
:D 'Here 'tis:
http://racingstudebakers.com/foo/viewtopic.php?f=1&t=3159
Cool beans, Joe. :!: :cool: BP
warrlaw1
06-03-2015, 12:10 PM
Good for Joe. Every time out teaches us something. Hope he makes the PSMCDRs in September.
R3 challenger
06-03-2015, 12:59 PM
'Looking forward to seeing you and your Lark in September, Joe. Good luck on the fuel situation. It sounds like many good suggestions have been made. The Plain Brown Wrapper is still using a stock, original fuel pump with the stronger spring. Fuel line is 3/8" from tank to the pump and original 5/16" from the pump to the carb with all fittings drilled out a few thousandths. I like to use a stock steel line for most of the run of the pressure line from blower to fuel pump, making sure that the fittings at the pump are not "metered" internally with a small opening. This has been enough to support mid-12s so far.
George
