Looking for something to replace original suspension. A bolt-on that isn't crazy money preferred. Recommendations?
Suspension Upgrade for Our '53 C Body
Frame / Springs: Suspension Upgrade for Our '53 C Body
Tim-'53 Starlight Commander Custom in Yuma, AZ
jimsrodshop.com/project/53-resurrectionTags: None
Originally posted by Alan View PostYou are going down a slippery slope. Money wise look at spending over $2,000. That isn't crazy, it is scary and the more you get into it the more you want to throw at it to get it right.
I didn't think there were any bolt on suspension modifications you could do to a Studebaker (brakes yes but not suspension). There's a complete "weld on" front clip ($2800) plus labor. There's Mustang II cross member and brakes but it's also weld on. I'm getting ready to install a Mustang II on my daughter's Silver Hawk but I'm doing all the work myself so the cost will be minimal ($1600-$1700).
Unless you're talking about some other type of modification???
Treblig
The Studebaker front suspension is very driveable and roadable, especially with the addition of a rear sway bar and radial tires. You merely have to replace some worn bushings and align it properly.
Something that is newer is not necessarily better, just because it is newer.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Roy is right!
I have two 53's one C and a K body, here in central Mexico.
the front end and rear are very smooth, most of my friends are surprised about this, and I'm talking bad roads.
In the past I was thinking the same, to install a Chevy Monte Carlo front end,
just get some radial tires that are not too wide and the steering is smooth also.
Originally posted by Mike Van Veghten View PostDoesn't the "search" function work on this site ?
MikeDon Wilson, Centralia, WA
40 Champion 4 door*
50 Champion 2 door*
53 Commander K Auto*
53 Commander K overdrive*
55 President Speedster
62 GT 4Speed*
63 Avanti R1*
64 Champ 1/2 ton
* Formerly owned
Depends on the words entered, whether the search is title only or body, and whether the original post had a properly descriptive title.Brad Johnson,
'56 Sky Hawk in process
I'm glad it's more than just I that thinks the original suspension works just fine. My 1950 Champion was restored 21 years ago with new bushings, tie rods and any normal wear parts. It also has radial tires and rides very well. The first comment from people that have gone for a ride is how nice the ride is.
Originally posted by Dick Steinkamp View PostTim,
What is it about the current suspension that is bothering you? That info may help produce some ideas.Tim-'53 Starlight Commander Custom in Yuma, AZ
Originally posted by paintim613 View PostFeel every bump, lots of lean when turning, side to side movement. BTW I am using radial tires but have not added rear sway bar. Thanks!We've got to quit saying, "How stupid can you be?" Too many people are taking it as a challenge.
You would be surprised at how nice riding a non worn out Stude suspension feels. Go for a rebuild and add power steering and you will be glad you did. I'd rather fix than switch. cheers jimmijimsigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
My '53K front suspension was rebuilt, changed the front swaw bar to one from '63 GT hawk, and added the rear bar from '55 president sedan. 6" rims with radial tires and saginaw PS box from a '57 hawk. It rides pretty well and although the steering is still slow by modern standards (but not as slow as the original manual steering), it handles pretty well I think. Lean in turns is not much and I can take cloverleafs on the interstate w/o slowing down much so can keep up with traffic fine. Only thing I wish was easy to change is the caster. A little too darty on the highway at speed IMO. I've adjusted it as much as possible but could use more.
Jeff in ND
