I have a 55 President. I can't find the kickdown switch. I note the throttle rod rotates, but I don't see anything attached to it or around it. Having problems with the OD going in and have a loose hanging green wire in the engine compartment also- (same color that goes to the lockout switch) that has an old "heat resistant wire" for final attachment. I just noticed it was hanging there one day over on the drivers side. Looked pretty beat up from the manifold heat (IMO). I've been going through everything with the VOM but I'm not having much luck thus far. Followed the schematic in the manual and found that the lockout doesn't have any power going to it through the green wire. When OD is engaged- free wheels only- no passing gear or upshifting occurring. Oddest thing is, I can't find a kickdown switch. Wondering now if there is anyway it could have been wired without one. I don't see any magical toggles anywhere. Worked well when I first go it a couple of months ago ( I think - the OD was in and the wheels were locked when in gear and sitting)- had to perform carb rebuild. About two weeks ago, I noticed the disconnected, hanging wire.- no power going to the wire. I don't want to fry anything. Suppose I could try hooking it up on the ignition side of the relay.- Don't think I bumped any wires when I undid the carb mounting and not finding a kick down switch is baffling. Thanks for any tips anyone might have.
Where's my kickdown switch
The kick down switch is generally mounted on the vertical rod (attached to the back of the driver's side head). It is activated by a paddle on the pivoting throttle mechanism.
I'm not sure what you are saying here... Worked well when I first go it a couple of months ago ( I think - the OD was in and the wheels were locked when in gear and sitting) This sounds like the OD handle was pulled out, negating the OD. The OD should work (all but kick down) without the Kick Down switch. (Free wheeling in 1st second third, below 28mph, shift when over 28 mpg when you let up on the gas, and not be free wheeling then.
Thanks for the quick reply.
As I remember it- the OD handle was in the whole time when I first got it. Seemed to be okay when sitting in first gear with the engine off- ie wheels grabbed and didn't free wheel. I might have been a little distracted when I first got this, however. I don't remember it wanting to move. So what you are saying is that if the handle is in and the OD is engaged- the car free wheels under 28 mph- it doesn't free wheel above 28 mph if everything is working? I thought that below 28 mph- the OD didn't function and therefore- no freewheeling. Right now mine free wheels whenever the handle is in and that's all that happens.
I'll check on the head. I think the temperature sensor attaches in that area too (fodder for another post).
Thanks,
Handle IN it should freewheel when moving forward at speeds less than about 30 MPH, which is the speed when the governor should send a signal to the relay to engage the overdrive solenoid.
Handle OUT it will be locked out of overdrive and locked out of freewheeling in all gears and at all speeds.
Shifting to reverse will lock the tranny out of overdrive and freewheeling.
Thanks all for the OD advice everyone. Now I've just got to figure out where the blanged green wire goes. (Same color as one of the wires for the solenoid- could be a hint there . Have to see about the continuity...)
Originally posted by Tom B View PostThe kick down switch is generally mounted on the vertical rod (attached to the back of the driver's side head). It is activated by a paddle on the pivoting throttle mechanism.
One wire that has High Temp. Black sleeve on it, goes down low on the Left of the Engine compartment near the Hot Exhaust Manifold for the Horn ground wire coming out of the Steering Gear, it usually is not Green but after this many years you can't be sure it is original.
The other wire I can think of like that, would the one that goes across the Top of the firewall at the pinch weld on the right side, it goes to the in-fender Climatizer Heat Fan and is Green it would have Power with Ign. Sw. on ACC or IGN. and AIR Switch ON.StudeRich
Check for a added-on toggle switch inside the car. Somebody may have disconnected the kickdown switch, and made the overdrive controllable manually from inside the car. Used to be an old hot-rodders' trick. On a '55 Commander, the kickdown switch should be mounted at the top of the tall throttle bellcrank mounted at the rear of the left-side cylinder head. If it is not there you should see one metal tab with about a 3/8" hole in it for mounting the switch, on the frame of the bellcrank, and an arm or "paddle" attached to the moving portion of the bellcrank, that will approach that hole at wide-open throttle.
The kickdown switch has 4 terminals. The pair nearest the mounting nut supply power to the solenoid; they are normally closed, but go open when the gas pedal is floored. The pair furthest from the mounting nut connect the ignition points to the grounding contact in the solenoid; they are normally open, but close when the gas pedal is floored. If you simply removed the kickdown switch, and left all wires disconnected, the OD would not work at all. If you joined the first pair of wires, the ones closest to the switch mounting nut, OD would engage as normal, but would only disengage when road speed dropped below the governor cut-in speed and the throttle lifted briefly to unload the driveline.Gord Richmond, within Weasel range of the Alberta Badlands
Originally posted by StudeRich View PostOne wire that has High Temp. Black sleeve on it, goes down low on the Left of the Engine compartment near the Hot Exhaust Manifold for the Horn ground wire coming out of the Steering Gear, it usually is not Green but after this many years you can't be sure it is original.
Gordr, I checked for a toggle switch on the inside and couldn't find one. Thanks for the great description of the components and how they work. I have ordered a kickdown switch to see if it's possible to just add it on. I think the problem of the OD not working though, probably has more to do with bad wiring and / or corrosion. I notiiced that the wire going from the lockout to the governor is very small. Until all these wiring issues get taken care of we're probably all just walkin' the dog...
Very appreciative of all the suggestions.
Other makes used overdrives so gordr you can not state wire position because someone could have used a non Stude OD kick down switch which will work but the wires will be in a different position. The kick down portion only needs one wire going to the ignition coil as all it does is ground out the points side of the coil temporarily. I pulled the kickdown switch off my T cab because everytime I used it sparks went everwhere. Could well be that this was the case in this carIf you car is ugly then it better be fast.....
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
Originally posted by gordr View PostCheck for a added-on toggle switch inside the car. Somebody may have disconnected the kickdown switch, and made the overdrive controllable manually from inside the car. Used to be an old hot-rodders' trick. On a '55 Commander, the kickdown switch should be mounted at the top of the tall throttle bellcrank mounted at the rear of the left-side cylinder head. If it is not there you should see one metal tab with about a 3/8" hole in it for mounting the switch, on the frame of the bellcrank, and an arm or "paddle" attached to the moving portion of the bellcrank, that will approach that hole at wide-open throttle.
I took your advice - this time I went where all the wires are- under the dash. Guess what I found coming through the firewall- yep- there she was sort of up there toward the speedo- four wires coming through the wall and connecting to the little square piece of metal. I was looking for it under the hood instead of inside. I noticed that the button was stuck in the kickdown position. I hit it with a little wd40- I'll try it tomorrow night eventhough I've got a new switch coming. Now that I see where it is- seems obvious. We'll be doing a little meter work before we start 'er up and go. A good learning experience for me.
Well, I was referring to Stude overdrives, obviously. Yes, I could envision some sort of oddball switch, in which the "near" terminals were N.O. and the "far" ones N.C., but given the construction of typical plunger-type switches back in the day, the arrangement I gave is likely to be the right one. And the kickdown side does need two wires. One goes to the ignition points (and thus, also the coil), and the other goes to grounding contacts built into the solenoid. That way, the short to ground goes away as soon as the solenoid releases, regardless of how long the driver's foot is to the mat. It has to be that way. If the contact went to ground directly, you would kill the engine every time you floored the accelerator, whether it were in OD or not, and it would stay "killed" as long as your foot was all the way down. That grounding circuit has to be temporary.Gord Richmond, within Weasel range of the Alberta Badlands
Check this out for some good information.
