I have a gauge cluster I'm planning on putting in my 66, but I noticed that the ammeter needle at rest is a little toward the charge side. It's enough that it's completely off the center line, but that's about all. I think when I got it it was in the middle and maybe I jostled it when I repainted the needle. Anyway, is it possible to somehow get the needle to stay in the middle at rest? Does this mean the gauge is no good? Having it off center bugs me.
1964-66 ammeter
Speedo / Tach / Gauges: 1964-66 ammeter
"Madness...is the exception in individuals, but the rule in groups" - Nietzsche.Tags: None
You bent it when you painted it. If your OCD is bugging you that much rebend the wire so it centers.If you car is ugly then it better be fast.....
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
That's what I'll do. I do not think I'll be connecting it. I found the cluster that was in the car had massive corrosion on the red wire connector and the lug that was still fastened to the terminal looked like it had seen some heat or something. I also found the thick red wire that is supposed to go to that terminal was spliced to a thick yellow wire that goes over to the ignition switch, I think.
Here are some photos of the mess. Too many splices! That red wire goes to a yellow wire and then to a white wire. Also, the wire for the cigar lighter had two splices in it and then was bundled with several other wires, so I had to cut it again to take the unit out so I could replace the woodgrain panel. Now when I put it back I'll have to add a third splice! I think every wire to the ignition switch has been spliced, as well. I also noticed that one light socket (you can see in the picture) has lost its metal contact to ground. I think I have a good one, but I'd have to splice that in. It's time for a new wire harness, but I don't have that kind of money. But I also now have an idea of the huge amount of work it will be to make this all right again.
Scott, that mess looks familiar to me. My wiring was all cobbled up also. After removing some tape on the harness to make some repairs I found the Yellow and Black wire from the regulator to the ignition had the cover melted off! With all of the poor hacks made to the harness it was an easy decision to rewire the car with a modern fuse box system.Gary
I would not waste money on a stock harness. I rwwired the 54 in part of an afternoon. On ce you get in ther you will wonder why the factory wired things like they did instead of simply using heavier gage wire and keeping the circuits simple.If you car is ugly then it better be fast.....
65 2dr sedan
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
Originally posted by Scott View PostCan I see the wiring diagram for a on-stock harness so I can compare with the stock wiring diagram?
Gary
Originally posted by garrilla View PostScott, here is a link to 63-64 wiring diagram. May be similar to yours.
https://www.studebakerparts.com/stud...wire-COLOR.pdf"Madness...is the exception in individuals, but the rule in groups" - Nietzsche.
Originally posted by Scott View PostIt's very nice to see it with colors!Gary
Gary, could you post one for a Stude Avanti??Originally posted by garrilla View PostScott, here is a link to 63-64 wiring diagram. May be similar to yours.
Hawklover:
I have one from ClassicCarWiring.com but too large to scan. Found one or two very minor omissions on it, but very useful.
http://www.classiccarwiring.com/1963...ceted_search=0
