Got a call from a friend who reassembling the left front fender on his 1938 Coupe Express and indicated that there was a 1/2" between the fender and firewall. (The bolt is in the wheel well, passes through the fender, and then screws into the side of the firewall quite away below the hood hinge) He asked me if this normal and if there was supposed to be a spacer at this location?
I had to tell him that I didn't remove the front fenders on my 1938 Coupe so I could not provide an answer but would probably be asking the same question in a few days as we are trial fitting my front end prior to painting.
The parts book lists part # 267880 as "spacer, fender to body bracker". Can anyone provide details on what should be present when the fender is mounted to firewall?
Thanks
Thanks
