I started replacing the shot rubber bushing in my 65 today and I ran into a snag with the Delrin kit that a vendor here offers. The vendor supplies fender washers and that is fine but when using this kit you also need to replace the retaining capscrews as the stock ones for the upper control arm do not have enough threads so the threads bottom out before the cap screw gets tight. The lower bushing retaining capscrews have threads to the head.
This kit is tapped so each new bushing has a grease zerc.
I have attached a photo to stress that when one has a shop do work on ones car that does not mean that the work was done right. Twenty some years ago I was driving my 65 and went from 65 MPH to zero in ten feet when I rear ended some lady backing off a freeway on ramp. I tore the front crossmenber loose. I sent the 65 to a frame shop where they straightened the front frame and welded the crossmember back in. Today I discovered that I have a cracked frame in the coil spring area. It will weld up fine with my wire welder.
