Just finished cleaning & oiling & filing the points on my '63 Hawk clock - Used the method described at:
raylinrestoration.com/TechnicalPages
Only diff. was that I was unable to remove the wind knob - Just could not get a strong enough grip on the wind shaft to keep it from turning. Was able to rotate the face of the clock (after removing the body) enough to clean and lube the mechanism. being VERY careful not to get any of the cleaner or oil on the dial face. Also filed the burned points (which was the main problem) to mostly clean condition.
While testing the unit (before re-assembly) noticed that the points sparked/arced at each energizing spurt - Probably the cause of the points burning originally. since the distributor points use a condenser (a type of capacitor) to reduce arcing, I tried the same w/ the clock, using a 100 mf 35volt capacitor (radio shack has them-very common). The arcing has been noticeably reduced. The value of the capacitor was "guesstimated" - perhaps some tech person can provide a more accurate electrical value.
Paul TK
Paul TK
