I have a general question on how the stainless steel moulding that covered the gutter (the upward flanged piece of metal where roof meets the body) was originally affixed to the body of my 1961 Lark 4-door wagon. I took it in to the body shop, and asked them to remove all the stainless and chrome. They began to take that moulding off, but seriously mangled it in the process - I told them to stop before they caused further damage, and inspected the construction of this piece of the car. It appeared to be directly pressed onto the body, perhaps mechanically, rather than tacked or screwed on. If that was the case, should it not be removed? If it has to be removed, how can it be replaced?
Stainless steel molding on the gutters of a 1961 Lark
Tags: None
I would never recommend that that moulding be removed...ever. I certainly don't have the skill or patience to do it plus you will probably never find replacement once it is damaged in the removal process...and it usually is. If the car is to be repainted, it can be masked and carefully sanded around it.
In fact, I would never have a body shop remove ANY Studebaker trim unless they have lots of prior experience with vintage cars. They are bound to ruin trim, loose attachment hardware and damage the body in the process.Dick Steinkamp
Bellingham, WA
Yes it can be R&R'd but it takes care and patience. Also, you need to find a safe place to store it when off the car. Easily mangled. I took it off my '53 since I needed to do some welding nearby due to rust holes (mouse nests in the headliner rusted the roof thru). If you don't need to and can buff it on the car I would leave it on.
Jeff in ND
Getting ready to paint roof on my 57 Packard wagon.
Looks to have the same type drip rail moulding. Also couldn't figure how to remove without destroying it.
Looked at it from all angles and decided to leave it alone.sigpic1957 Packard Clipper Country Sedan
Lt. Col. Jimmy Doolittle
The molding has a slight bit of a spring to it retaining it to the drip rail. The lower edge has a lip to secure it. As Dick said do not remove it. Even if you were able to remove it without damage. Painting the drip rail makes it all the harder to reinstall due to the thickness of the added paint. On my 66 Daytona the drip molding was removed by the upholstery shop when the vinyl top was replaced. Even an expert with years of experience couldn't do it without damage. If my memory is correct, later manufacturers retained the vinyl with another stainless strip that held the tops between the drip rail & the roof.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
The way to safely remove that is to use an old beer bottle opener. Even though the modern paint can openers look about the same they will not work. With my
trusty Hamm's beer opener I removed the stainless drip rail on the speedster with no damage. When done it's handy for opening beer bottles also.
Thanks for the advice - I had told the body shop to leave it on, but they discovered some bad rust just above the gutter line that prompted its removal. The two pieces that they took off can probably be repaired, but needless to say, I wasn't happy. I have since let them know to keep the rest of the gutter moulding in place to avoid further headaches.
you left well enough alone cheers jimmijimOriginally posted by 57pack View PostGetting ready to paint roof on my 57 Packard wagon.
Looked at it from all angles and decided to leave it alone.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
