The last couple of Stude V-8 engines I rebuilt both had a load of gunk in the lifter valley, in the indentations beside the lifters. That nasty gray gooey stuff that takes forever to clean. At the shop where I work, the owner was rebuilding a V-8 Oldsmobile engine probably late seventies or early eighties. Looking at the lifter valley, the Olds engine had the same small pockets the the Stude engines do but, each little valley had about a quarter inch hole drilled in it to facilitate oil drainback into the oil pan.
Has anyone ever done this to a Stude block? Once that oil gets into those little valleys, it doesn't seem to ever leave. As hard a time as a Stude engine has to get oil back to the oil pan, this seems like it would help.
