I've been having trouble with the brakes sticking on my 49 Champion business coupe, which I believe I've traced to the hill holder (now that I recognize that it has one). I've disassembled and inspected the brakes on all 4 wheels, and, while I found some significant problems from the previous owners work, nothing explained the brake sticking I was experiencing. The master cylinder appears to have been replaced. braking power is good and even. The hill holder works, but sticks in the on position. On a hill, I can let the clutch pedal all the way up with the car in neutral and it still holds, which I gather from other posts, it's not supposed to do. It doesn't release properly when I go forward on the hill, but I can get it let loose most of the time by tapping the brake with the clutch pedal all the way depressed. The spring on the adjustment shaft was a little loose so I stretched it some and I think the lever is all the way back with the clutch engaged. Have ordered a seal kit from SI. These units are apparently some trouble to reseal, so I'm wondering whether there are other suggestions. If I flush with alcohol as some suggest, can one tell on the bench whether it functions?
Thanks for any help you could provide.
Ron
Ron
