When I purchased my 56 Golden Hawk from the previous owner he stated that the rear wheel bearings need to be regreased every 10,000 miles. There is a hose that comes off the axle and rises up to the body and I have noticed a discharge of grease from it. Should the bearings be greased this often and is the discharge of grease from the hose normal. Hope someone can give me a answer.
rear wheel bearing
Tags: None
Yes TECH covers this. In order to grease the rear wheel bearings require removing the brake drums and the axles. This reqires two seperate pullers. Not a easy task. I just did mine. I had 90W gear flid leaking out. I check the bearings and they looked fine. And there was some grease on the bearings. But the leaking inner seal was hard as a rock. The outter seal is a felt and it also leaked. I am replacing all seals and checking the end play. What a job! I wish there was a grease fiting to lube the bearings but the recomendation is to pack the wheel bearings is 25,000 miles.
If I remember correctly, the 1956 Hawk rear wheel bearings have a provision for packing through a plug on the rear of the axle flange. There is a slotted 1/8 inch pipe plug that has to be removed and a zerk fitting installed to do the job. If the bearings are packed in that manner, be very careful that excess grease isn't forced into the brake drums. Bud
doofas.....Why would there be a hole to drain something that is not there?If you car is ugly then it better be fast.....
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
