Tri-Point Emblems
  • Tri-Point Emblems
    Tri-Point emblems were apparently used on early '53 cars but not late '53 due some apparent inside pressure from MB. Were those same Tri-Point emblems utilized on '52 and '51 models, and if so was it only the V8 equipped models? Thanks, Dan
    No tri-stars anywhere on '51 or '52 that I've ever seen, Dan, and I've resurrected all three years.
    My own '53 is an early model assembled April 30, 1953. In addition to the tri-stars on the hood and trunk and wheel covers, the tri-stars appear on the "Commander" script on the trunk, the rear seat ashtray cover, the radio delete plate and the horn button. Each of these disappeared as the factory used up their stock so, later models still sport many of these.
    Brad Johnson,
    '56 Sky Hawk in process
      There was a very nice one on ebay that just expired with no bids. I almost bid, just because it was so cheap, but I'll probably never be lucky enough to own a 53.
        I think the reverse light lenses were Tri-star on some earlier cars, and Also the Commander script was available on the trunk lids of 52's IIRC. But, It's been a long time since I've seen one, and the snow may have froze my brain today!
        Bez Auto Alchemy
          You are right, Brad. I did forget the back-up lights.
          Brad Johnson,
            Yes, I've seen more than one '54 (!) model with the tri star back up lens (original 1954 cars)
              Probably the most obvious were the early '53 Wheelcovers with the Tri-Star.
                Originally posted by CarCrosswordDan View Post
                Tri-Point emblems were apparently used on early '53 cars but not late '53 due some apparent inside pressure from MB. Thanks, Dan
                Your statement is only correct for South Bend assembled cars. At the Vernon (LA) California assembly plant, all 1953 models had the tri-star emblems.
                  All, thanks for the helpful responses. Dan
                    OH! Hey Dan, I just noticed no one answered your question about 6 or 8's. The TriStar was used on both, the Six had a Y/S and the V8 had a Y/8. Just as the V/S and V/8 that replaced it.
                      Here is the 52 trunk"Commander" emblem with the Tri-star[s]
                      Bez Auto Alchemy
                        Looks like a V8 emblem not a tri-star.
                        Stu Chapman
                          Hamilton assembled cars had the tri-star emblems as well but I don't know for how long. Gary, you'll remember my Hamilton-built Maui Blue Starlight Coupe that had these emblems.
                          Stu Chapman
                            Would '52 horn button be considered as having that emblem? Or too short on the bottom side?
                              No, Stu. Brad is referring to the "Commander" script to the right of the license plate. It actually has two tri-stars included, and was available in '52, '53 and '54. Part # 299589W
ID:	1695750 And, Patrick, I think Mercedes-Benz probably objected to the '52 horn button as well.
                              Brad Johnson,
