View Full Version : How do you remove HAWK GT dash switches ?
starlightchamp
11-06-2007, 05:43 PM
Seems it should be simple but I already have scratch marks from trying to loosen the
durn nuts. The are circular with two small notches opposit one another. I tried using needle nose pliers but the switch shank won't let me get them at the right angle. Also tried small
visegrips but not enough nut edge. Is this a special tool need? Also tried tapping the indent slot with a small scewdriver. Suggestions please.
...Dick
1950 Champion Starlight
1963 Hawk GT
Santa Barbara
CA
http://farm1.static.flickr.com/125/368321841_7d3a05da00_t.jpg
http://farm1.static.flickr.com/185/367175252_40e3cec1d9_t.jpg
41 Frank
11-06-2007, 06:00 PM
I made my own tool to remove the switches out of a piece of pipe by grinding down the end to leave two raised areas opposite each other that fit in the notches of the switches and than welded a piece of rod on top for a t-handle.
JDP
11-06-2007, 06:01 PM
There is a special tool, I have one that a friend made for me. It has two little tabs that fit in the slots. Eastwood tools sells one, but it's not really the right size.
JDP/Maryland
63 R2 SuperHawk (Caesar)
spent to date $54,758.75
64 R2 GT (Sid)
spent to date $62,439.30
63 Lark 2 door
52 Starliner
51 Commander
39 Coupe express
39 Coupe express (rod)
11-06-2007, 06:48 PM
I used a tool used to install fender mounted radio antennas. There are a couple of different sizes and one was just right.
GTtim
11-06-2007, 08:24 PM
Maybe one of those needle nose pliers that have the jaws bent almost ninety degrees?
Tim K.
'64 R2 GT Hawk
parky
11-06-2007, 09:49 PM
Electrical rigid conduit works really well. It is thin walled and can easily be filed down to provide the two tabs you need. When you get the piece filed down so the tabs are protruding, the piece can be persuaded (with a hammer) to obtain the proper distance between the tabs.
Parky
62 GT Hawk
mapman
11-07-2007, 09:15 AM
I have used nut drivers filed to form the prongs, and air chuck filed to prongs(wrench fits), and tubing filed to prongs, an old wrench filed to prongs. I have nearly a whole set now. Make sure the center hole is big enough and long enough. It just takes a few minutes to make and no more scratches.
Rob
starlightchamp
11-07-2007, 12:27 PM
Thank you all, I was wishing for an easier solution than making the tool but
that's where its at. The electrical conduit sounds like the place to start since
I will have to hacksaw and grind the ends to form the tabs. I was going to use steel
water pipe but that is too thick wall. Anyone know what this type of nut is called ?
Thanks again.
...Dick Curtis
1963 Hawk GT
Santa Barbara
CA
StudHawk60
11-07-2007, 03:39 PM
Don't ya know, that in South Bend, in a shed or barn someplace, there sits a dusty box just full of the sockets used to install these special nuts.:(
Jerry Forrester
11-07-2007, 04:26 PM
quote: Anyone know what this type of nut is called ?
I do, I do.
They are called GT Hawk Switch Nuts.[}:)][}:)][}:)]
Just couldn't help myself.[:p]
