Hi Guys: The Hawk is up and running just fine, but I find that since I rebuilt the Control valve and replaced all of the hoses on my Bendix power steering I get assist on a Left turn just fine but apparently none on a Right turn. Could this be an adjustment issue or something else. I have driven the car a couple of times and topped off the fluid level in the pump. Don't know what else to try? Any assistance would be appreciated.
Power assist on Left turn, none on Right?
The way I adjust this type valve on mustangs and corvettes is lift the front wheels off the ground, start the engine and center the wheels,then slowly turn the adjusting nut in until I see the wheel just try to move. Then back it back off counting the turns until it starts to move the other way. Now put it in the center of the amount of turns that you counted.
It may look like a Mustang or Corvette unit, but it is not. Probably the spring may be broken. Or the spacer inside the spring is missing. It HAS to be there, as it helps with the adjustment. To adjust you tighten all the way untill the spring tension stops against the spacer, then back off the nut 1 flat....less than 1/4 turn. Needless to say if the spacer is there, then you can't use this method to adjust.Bez Auto Alchemy
Bez that's good to know I have to rebuild mine next month. I'am sure when I got it apart I would have though something here doesn't look right. Thought at one time I saw a post about using a mustang valve on a Stude. I've redone a few corvette valves. I don't really care for this kind of a system. I would much prefer a power steering sector. Had thought about trying a astro van but looks like a whole lot of work.
Originally posted by swvalcon View PostBez that's good to know I have to rebuild mine next month. I'am sure when I got it apart I would have though something here doesn't look right. Thought at one time I saw a post about using a mustang valve on a Stude. I've redone a few corvette valves. I don't really care for this kind of a system. I would much prefer a power steering sector. Had thought about trying a astro van but looks like a whole lot of work.
