I'm getting close to removing my conv body from the frame. I know this is a delicate undertaking with the conv. All panels have been aligned properly and I intend to weld a temporary brace from the top of both hinge posts to the rear quarter area to maintain the alignment after removal. The body will go to the paint shop while the frame and mechanicals get restored.
Anybody done this before that might have some words of wisdom? I plan to set it back down on the rebuilt chassis, the engine and trans installed with the weight on the tires. I will then fill the gaps between the body mounts and frame with shim just enough to fill the existing gaps, install the frame to body bolts and tighten, then cut the welds lose on the door braces. Is this a good plan?
