1963 lark starter stuck
The Folo-Thru Drive is supposed to disengage automatically (due to centrifugal forces) when the speed of the flywheel is around 400 rpm. If yours does not, try to lubricate it with thin oil. Don't ever try to push it in tne rearward position (and don't ask me how I know!) or you will ruin it. If the lubrication does not help, you're good for a new one. You'll find some info there: http://g503.com/forums/viewtopic.php?f=4&t=74938
Best of luck and nice day to all. (Of course it's a good day, it's friday!)sigpic
Remove snap ring at base of starter drive "bell" and dis assemble. clean all bits. reassemble. to get drive down spin drive against direction of splines while mounted on armature. use the wire brush on a bench grinder. plan "b" take to local rebuilder and follow their suggestions.someone who does farm equipment starters and automotive starters can help you out. Good Luck Doofus
Well I think I got the starter taken care of found a new drive for it but it looks like the few seconds that it was stuck spinning it knocked 2 teeth of the fly wheel. Not sure how that happen it was only stuck for afew moments before i realized it and shut it down. Oh well looks like its time to hunt down a new flywheel and pull the transmission again
Originally posted by azer133 View PostWell I think I got the starter taken care of found a new drive for it but it looks like the few seconds that it was stuck spinning it knocked 2 teeth of the fly wheel. Not sure how that happen it was only stuck for afew moments before i realized it and shut it down. Oh well looks like its time to hunt down a new flywheel and pull the transmission again
Originally posted by Son O Lark View PostIIRC The ring gear can be replaced on the six cylinder flywheels.sigpic1957 Packard Clipper Country Sedan
Lt. Col. Jimmy Doolittle
Flywheels and Automatic Trans. Torque Converters are TWO completely different things. The Six is not a lot different in that regard from the V8.
The Ring Gear on the Flywheel of the Standard Trans. Cars, is removable with Heat, not welded.
Torque Converters have to be re-built by a Converter rebuilder with the proper equipment to properly weld on a New Ring Gear, center and balance a Converter.StudeRich
The 63 Wagonaire ring gear episode was quite a few years ago.
And my brain is a bit fuzzy but, If I remember right (?).
The welder took my converter with defective ring gear attached.
And made up a jig with correct measurements for depth and hight and then removed the old ring gear.
Placing the converter back in the jig, he tacked the new gear in place.
He then placed the assembly on a lathe and spun it to check for balance.We were lucky I guess as it ran true.
Put it back in the car and never had another problem,sigpic1957 Packard Clipper Country Sedan
I replaced the bendix on the starter what happen the old one the pin had fallen out that holds it on the shaft. I stuck the starter back on and disconnect power to the distributor cap and cranked it over a dozen times the starter never did grind or skip. I guess for now Ill leave the flywheel alone and if it starts giving problems then ill pull it.
Azer you dodged a bullet! the ring gear is easy on man. trans flywheels. just need heat from oxy acetylene torch. the ring gear sits against a shoulder on flywheel and any worthy welding shop can do it Good Luck Doofus
