I goofed and sent this with the wrong heading, so I'll try again.
I'm at the point of mounting the supercharger bracket on the engine and I find that it does not fit correctly. The major problem seems to be that the lower arm that attaches to the water manifold is about 3/4" too far rearward. If I bolt that part to the water manifold, then the parts of the bracket that bolt to the upper right water outlet in the water manifold are about 3/4" too far forward. Likewise, the lower bracket that bolts to the exhaust manifold is also too far forward. It looks to me like the lower arm is curved, i.e. bent rearward. Is this a common problem and if so, how is it corrected? Thanks.
