does a r2 fuel pump put out more pressure than a r1 tks.
r1/r2 fuel pump
The R-2 pump is able to boost pressure with the tube from the supercharger to the fuel pump diaphragm so yes, it does put out more pressure. When I first restored my Hawk to having a supercharger it was still running with the regular pump. On boost situations the pump could not overcome the pressure of boost from the supercharger & would die out. Installing the R-2 pump & the pressure line solved that issue.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Well, it's a trick question. At non boosted operation they are the same, but once the supercharger adds pressure to the top of the diaphragm, then it puts out more pressure.
It varies proportionately with the boostBez Auto Alchemy
If your running the Edelbrock 1406, just like mine, it runs rich. I re-jetted mine and it solved the problem. Also run Petronix ignition to burn the excess fuel. That helps drastically to.Last edited by cobraman428; 02-01-2015, 03:25 PM.
No, do not use an R2 Pump for a R1 application. The Diaphragm Bowl VENT is plugged on all Pumps made properly for a Supercharger.
If you HAVE to use one, it would take disassembly to drill out the vent in the top and of course plug the S/C reference line hole.StudeRich
you can always go to a electric fuel pump at the proper psi. that would also help with any hot weather problems. i'm sure several Studebaker Vendors have them, if a flaps doesn't...Kerry. SDC Member #A012596W. ENCSDC member.
It is the Carter MODIFIED Super Pump replacement for the Original Carter R1 or R2, do not try this at home folks, these 318/360 Dodge Pumps have been professionally, Custom modified before being sold as Studebaker replacements.
As always the Performance Parts Turning Wheels advertisers are there when you need them, at least FIVE or more!
http://studebakervendors.comLast edited by StudeRich; 02-01-2015, 08:02 PM.StudeRich
A few years ago a friend of mine bought and installed a Carter MoPar performance fuel pump on his Studebaker V-8. He drove it for awhile, and then the arm actually broke on it. (He hadn't asked my advice beforehand.). So, as StudeRich says, if you don't know what you might encounter...don't do it!
Originally posted by StudeRich View PostNo, do not use an R2 Pump for a R1 application. The Diaphragm Bowl VENT is plugged on all Pumps made properly for a Supercharger.
On the Carter small block Chrysler pump, It does NOT just bolt on. You HAVE to bend the arm to work on the Stude eccentric.Bez Auto Alchemy
The Carter AFB and Edebrock are specified for 4.5 to 5 psi of fuel pressure. The MOPAR ones I have seen produce anywhere from 7.5 to 9 psi, which MAY cause you to flood at idle.
I have never had an original R1/R2 Carter fuel pump to tell you what they put out in fuel pressure.
BUT, Studebaker did use a bleed back fuel filter, when at idle, fuel is diverted back to the tank, or to the inlet of the fuel pump, which would keep the pressure low at idle.
If you are missing that fuel filter and return line, and running a MOPAR fuel pump, and it is putting out 9 psi, you will have issues.
If running just as an R1, you can use a simple fuel pressure regulator. If you go to R2, you will need a pressure regulator with boost reference (just like on the fuel pump)..
Or just install the original fuel filter and return line.
