Still working on the 62 convertible. Working under the dash, I found a vent, and looking through the box-o-parts, found the vent handle. Then, I discovered the OD handle is bolted in the place for the vent handle. So, now, the question becomes; where does the OD handle belong? Vague memory tells me it belongs on the passenger side of the steering wheel, but I am not sure. I have no doubt someone out there has an answer. This is probably the best place I have laded in for quite some time. Thanks, all, for the assistance!
Od cable handle location
The Right Air should be on the right side of the column.
Then outside-in from Left, Hood, Overdrive, Left Air.
A simple way, is to find the cable that goes to the Transmission and it will be the Overdrive shift cable.StudeRich
I do have a shop manual, and I have been using it extensively. I didn't think to look in it for pictures of the handle locations. I'll try that.
StudeRich, the right air you refer to, is that the lever to control cabin/defrost air flow? Or is there another right side vent? I'm a little lazy, and haven't looked under the dash to see, besides, I have to walk down to the shop to do so!! Its cold and rainy here.
