I am also replacing the pinion seal on my 1955 dana 44 rearend. not seeing anything in my '53 shop manual about marking the flange and shaft I just went ahead and used a impact wrench and removed the nut and the flange pryed off fairly easy. now browsing at some prior posts, they say you should mark them. At the same time, futzing with my emergency cable I also rotated the wheels. what kind of problem(s) can I expect when I go to put the flange back on? Are the splines not even or some thicker than others? I haven't tried it yet because I was reading these posts just before going to bed. Thanks for any info
pinion seal
